High beams not working
Fuquay Varina, NC
I'm installing a Dakota Digital gauge cluster in my 1980 BJ41. The installation has been pretty straightforward, but I've run into one issue: my high beams no longer work.
They worked perfectly before the install. As soon as I removed the high beam wire from the factory round plug, they stopped working.
I remember reading that on certain model years you need to add a ground or make a wiring change for the high beam indicator circuit, but I can't find that post again.
Has anyone run into this on a 1980 BJ41 or know what I need to do to get the high beams working again? Any advice would be appreciated.
Does anyone have a wiring diagram on the bright light switch and where its pickups power and ground ? I’ve searched and can’t find one.
Are you saying the high beam lights don't work, or do you mean just the high beam indicator?
The high beams aren’t working. When I push the high beam lever forward, the high beams do not work anymore. They worked prior to unpinning from the round plug for the Dakota gauges. My assumption is the power and ground came through the factory round plug. Not sure though.
The high beams are earthed via the high beam indicator in the dash, so your new gauges will need to be connected to the existing high beam indicator somehow.
Thank you for the response. That’s the piece I’m trying to understand. I can’t find the correct wiring harness schematic or someone else’s experience/wisdom they can share.
