My 07 has the mounting points below the headlights for the Denso HID ballasts, so they must be available in some country. I will be installing the Denso ballasts and a rebased 9006 HID bulb designed for reflector housings next week
Way past that. I use only Toyota parts for ballasts and had Phillips bulbs rebased to use the DS1 connector that Toyota uses. It also aligns the filament in the reflector correctly to get the optimum pattern. Light does not refract everywhere and the pattern is good. You can buy bulbs for either reflector lights or projector lights and contrary to popular belief they are not just for show. I will be only changing the low beams. I have 100W high beams already and want to keep the flash to pass feature.Which HID kits are you using? Most of the chinese one's are crap. A few good manufactures make a decent product. Digital systems are the way to go, but they are expensive. They produce a more accurate color and will be the same brightness from left to right (which is a problem with analogs).
The LC I believe uses a 9006 for the lows, 9005 for the highs, and a 9006 for the fogs. If you were to get these all converted to digital HIDs, you would be looking at 3 * $440 = $1320. That's damn expensive just for headlights.
Here's a good sight to look at. I've heard positive reviews from people.
Xetronic Digital Lighting System - 9006 Type (pair) - DBX9006
Remember you will also need a device to disable the on-board warning because it will show that your headlights are burned out, or just deal with the warning being on all the time (unless Toyota can disable this, I'm not sure.)
Also, remember that HID reflector conversion kits are not DOT legal and therefor are sold as "off-highway only". In the US, you will get a ticket if you pull up behind a cop with your headlights on. At night, obviously you have no choice.
HID reflector conversions are rude to other drivers. Being that your headlights are at the height of a sedans rear-view mirror, you will blind them with a powerful kit.
HID's were DESIGNED as projector elements, NOT reflector. Putting an HID bulb in a reflector housing just throws light everywhere.
The main reason why people use HID conversions is for show. It looks sick to have UV purple headlights with a deep yellow fog lamp setup.
I would just stay away from them personally. No reason to risk a ticket or spend the money.
To each his/her own though...
WHAT? Only 50w??
Might as well should've gone for the 80 watters.
Be sure to post the end result with comparison pics.
My install is on 100/200 series headlights, but yes you can just by a kit and plug everything in, but no one makes a Toyota OEM kit, so you have to put it together yourself. Also most kits come with off the shelf, China made bulbs that are designed for a universal application. They do not place the filament in the correct position for a correct pattern. That is very important for me.
