I need help My 1995 1hz 80 series has stopped supplying power to the rest of the car from the key when i turn the key to on i have no dash lights no clock just the door open and the cab light now i have done the Am1 main fusible link i have changed ignition switch out also i have changed starter relay out and the car is still dead the battery is full i did try to jump start but still no power it does not even wake it up and no i wont be checking the stater switch wire as its not sending signal in the first place from key through i have run through testing for continuity through all the main relays and they are all still good also and i still have nothing please HELP
