Hi Steer/Spring reversal question
Orting, WA
I have a 74 fj40 soa, cut and turned, with mini-truck knuckles and Marlin Hi-steer. I flipped the springs front and rear and now my tie rod is hitting my frame. When I rotated my knuckles, I added 4 degrees to factory castor to compensate for the large tires. Has anybody else had this problem I guess I could lower my bump stops, but that would limit my flex. Any suggestions are welcome.
why are you adding shims if you're cut n turn? the whole point of cut n turn is to fix caster when adding lift and tires.
what's the lift on your hi steer arms? where on the frame is it hitting? straight up? if so, then you will need to lower your bumpstops.
i didn't add shims. Let me clarify, I rotated the knuckles an additional 4 degrees beyond stock castor to compensate for the larger tires. I can't put the tie rod under the steering arms because they are tapered for fj-80 tie rod ends. When I get near the truck with a camera I will post a pic.
