Hi-Lift Jacks
jebber
Brokedown southa Dallas
N. Tejas
I am in the market for a trail jack. What is an appropriate jack size for an 80 with an OME 3" lift and 295's? Looks like the options are 36", 42", 48", and 60".
I have the 48 and rarely, if ever, max it out. That being said, the 60 would be nice for peace of mind, especially if you think you may go the 315 route or bigger some day.
If I were buying one, I'd get a 60". The only problem is storage. I'd figure out a way, though.
I had a 48" given to me, and so far it has worked- although I haven't tried changing a rear tire with it yet. I suspect I'll have to ratchet strap the rear axle when I do, or use someone else's spare as a spacer under it. I've done that to get the rear out of mud.
-Spike
I bought the 48 originally, then picked up a spare 60" bar -- the current set up is with the 60.
the 48" bar sits in my garage.
my suggestion is that you get the 60. It doesn't cost much more (if at all) and there's no need for you to jack it all the way up to the top, but if you need to, you have the option.
I know a lot of people are into "brand name" stuff, but 4WheelParts now carries a 54" jack that's well-priced (currently 20% off) and offers a few small extras like the handle isolator and the top clamp included in the price. Might be a good "in between" size for you. It's branded Smittybilt but it's made in China. Quality seems fine though.
YMMV, I am NOT a serious wheeler just like expeditions and I found myself in a weird predicament.
I've only used mine once. I had no base plate at the time. I had a flat and the truck was dipped on the passenger side. The flat was on the driver's side. Now granted I probably should have driven to someplace flat in hindsight but I didn't. I have stock height on 31s but with the 48" on that angle and with very soft soil I was having a tough time getting the 48" to NOT feel like it was going to come crashing down on me. If I were to buy one again I think I would go with the 60".
I've learned a long time ago about not trusting ANY Chinese steel. :mad:
I have to agree with the 60" crowd. The '80's suspension has so much travel that the biggest trick is getting the damn wheels off the ground with out the jack falling over. I even have that trouble with my 48", so I agree with Brett, but can see the advantage with the 60" to cover most situations as NorCalDoug said. I like Spike's idea with the spare, you can even use your own, unless your changing a flat on your own rig. The one thing that is not optional is caution! The second worst feeling in wheeling is working around, on or under an unstable raised vehicle, and the first is when said vehicle lands on you. My advice: proceed with caution! My .02
BTW, I kinda like ARB's exhaust jack. Kinda cool.
Stay away from the Big Red or Torin jacks, I had 3 break on me and finally switched to the Hi-Lift. As far as 48" being enough to lift a Cruiser on 265's, I've never had a problem.
No one has mentioned it yet but I would always keep a board to mount your hi-lift on to keep it from sinking and make it more stable on uneven ground. I've even taken it a step farther and made a wide platform that my jack can bolt too. If you're headed to gooey, bottomless mud, take a long section of 2x4 and you can use that to keep the jack from sinking.
The more you use it, the more you'll learn all the various tips and tricks.
If you're on flat ground, 48" may be fine. But if you find yourself high centered on a rock or in some off-camber situation, the extra 12" can be critical.
2x on the build quality of the Hi-Lift brand. One of the first times I used mine (and I would NOT do it the same way again), the truck moved and the "I" frame bar twisted and bent. I thought for sure it was ruined. But after I got all the weight off the jack and looked again, it was perfectly straight. I was amazed. Those things are tough!
And as long as I'm throwing in free advice, do heed all the safety recommendations about two hands on the jack at all times and especially two hands on the handle when lowering. 80's are heavy vehicles and the handle can come up with surprising speed and force. Even knowing this and practicing the two-hand method I narrowly missed getting badly hurt while jacking on NorCalDoug's truck while on the Rubicon.
MadBaggins didn't. Miss, that is. He still swears I punched him while he wasn't looking. :D
-Spike
The 60" bar also has other useful purposes.
I drove the rear tire onto its end a year ago (w/ a wood block underneath the bar), put a bottle jack on the other end of the bar under the frame (another wood block underneath the bar where the jack was used), wrapped a chain around my bent lower control arm/60" hi-lift bar, and jacked the bend away.
I did something similar with the drag link many years ago as well as fixing the rockers by pulling on the pinch joints a couple of times. The most recent rocker smash is beyond pulling on the pinch joints for repair. :frown:
Buy the Hi-Lift brand. It is only a little more and if a cheaper one failed it most likely would be at a critical time, like when YOU are under the truck!
Durability experience with mine is that 8 yrs ago at 50mph it fell off my lifted Pathfinder's roof rack, bounced down the highway, was ran over by an 18 wheeler and I have used it multiple times since. THAT is durable!
Kevin (Tools R Us) pulled this out of his little- bag -of -tricks on a trail run at Bulldog canyon using a hi-lift. Broken axle on a 60 and used it to keep the wheel and broken axle from working its way out as we backed it down off the hill. Many uses.
... Even knowing this and practicing the two-hand method I narrowly missed getting badly hurt while jacking on NorCalDoug's truck while on the Rubicon.
:whoops:
It was a useful lesson for me. I thought I was going by the book and doing everything properly and still wound up with a cut on my nose and a small black eye. And others I know and respect (e.g. Mudrak) told me similar things had happened to them. Just saying these jacks need to be treated with great care.
