Hey, Do ya really need that snap ring?
The Sunshine State
In the hub....ya you know the one... :mad:
if we dint the hub job would take like 5 mins....Im gonna groove that lil fawker with the dremel next time....
haha or maybe i just need better snap pliers.
I hear your pain...never heard more swear words than trying to remove/reinstall that little fawker...and then I found a pair of snap ring pliers that make it a cinch. The jaws are flat blades, with a cross-hatch pattern on them. Insert the "blades" inside of the opening on the snap-ring, squeeze the handle, and off it comes. Piece of cake. No clue where I bought it though.
I have a snap ring pliers similar to what lovetoski is describing. It makes the snap ring removal/reinstallation a ...well, a snap. It is a craftsman and if memory serves me correctly, it cost less than $20.
Another vote for the craftsman snap ring pliars. I bought mine at a garage sale for $5. Best $5 ever spent.
if you're talking brake dust shields, technically, no, you don't need them, but they help keep crap off the rotors/calipers and do help somewhat to protect the rotor.
lowtideride said:
ok heres another do we need it things....my dust shields are rusted and look rather crappy...do we need them too?
I junked mine. You need to cut them to retain the inner circle for proper spacing. I find I get much less crap on the disk without the. But our wheeling is mainly sand, snow, and mud....great stuff to pack between the caliper and dust shield.
ok, on my one hub the cone washers flew out with a few taps.....but on the other side they were way too tight and are pressed in....ive tryed pliers and screwdrivers and hammers oh my.....they wont budge.....can u use the torch to heat them up?.....will that even work?
Sometimes you need to repeatedly hit the studs pretty hard using a drift and hammer.
I like to use a nut to protect the thread, just in case.
If you want to try heat, you need to heat the hub/washer area and then ice the cone washer.
In this case, what you heat, expands... what you cool, contracts.
Can't say this method worked well for me, though.
Brake shields, and other ramblings.
Believe it or not, I just took the front brakes off my car for the first time since I got it. (actually, I think I put new pads on it right after I got it... 7 years ago.) Mainly to see how the dust shields were attached and remove them. I noticed that the inner wheel bearing seats against the dust shields. Did you guys keep the center part of the shield and trim it off? or remove it completely?
Also, can you get that cloth seal, or whatever it is behind the dust shield? I've never seen anything like it before.
I can't believe how good my brakes look, after 25,000 miles, dozens of autocrosses, and a couple of open track events.
They overheated at the opentrack events, even with the ducts, but the pads have so much material, they almost look new. The rotors are also in great shape... I'm tempted to just throw it back together, and hope they'll stay cooler and not fade as bad without the shields...
Naw, I'll probably upgrade the pads at least, and put on some braided lines.
I also run synthetic brake fluid.
I'd like to upgrade to the 12.19 wilwoods, but don't need the hassle... maybe this winter. Besides, I can't find anyone who can get them.
holy crap so thats what it looks like clean:eek:
