hesitation/vibration/sputtering after Amsoil ATF replace
Tampa, FLorida
Hello all,
I am new to the forum as well as land cruisers. I have been driving LR Discoveries for most of my life and let me tell you, Worst rigs ever made IMHO. I LOVE my 97 Cruiser 40th edition with ONLY 75K on the clock. The PO did not even know what diff lock was. He just kept it in his garage. The rig still has the underbody coating. Not for very long though. Although i do not have front or rear lockers i love the rig nonetheless. I will post some cruiser porn later.
I am having issues with my rig. The PO never did any PM except change the oil 3 months or 3000 which ever came first religiously. At 80K I have put only AMSOIL products in the rig. Being a dealer helps as i get pretty good deals.
Recently, I changed my tranny fluid with AMSOIL Universal ATF following one of the threads here on MUD. Once complete, i had put over 13.5 quarts. I ran it and i could barely notice the gear shift. It was amazing.
2 weeks later I am trying to drive off the line and punch the accelerator and notice hesitation/vibration/sputtering/speed bumps occurring and only from full stop to moving. Furthermore, the issue does not occur when the rig is cold but driving stop and go in NOVA traffic the issue emerges when it gets to operating temp.
I have ordered plugs, wires, fuel filter and will change that to see if it could just be a tune up issue. I would just like some help so that I can pinpoint this issue and be done with it, instead of guessing at what could be wrong.
I also would like to point out that when cold the ATF dip stick reads WAY HIGH. Could this be an issue? Could filling up ATF at a higher level cause this hesitation on start up? I don't know.Please Help!!
Thank you,
FJ raamis
Congrats on the purchase. I love my '97. I would say that the first order of business is to lower the trans fluid level to the right level. If it is reading high cold, it will only be worse as the fluid heats up.
Congrats and welcome. You're two quarts over. Check out chapter 4 in the FAQ for great info on baselining your 80.
Agree. The first order of business is to get the proper level of fluid.
If that does not help, the next thing to do is a "Rodney Flush" with a Dexron type fluid as is called for in the FSM. Universal ATFs may be ok, but they have to make compromises to work in all systems. Why not just use the fluid it was spec'ed to have either conventional or synthetic?
Many here have had good luck with Mobil1, but for flushing/diagnostic purposes you could save a few $$ filling it with conventional ATF. If that solves your problem, next time it needs service, go back to synthetic.
Other than fluid and adjusting the kick down cable, there is basically nothing you can do yourself to the transmission.
For the Rodney Flush-search using those terms here. It basically is a passive flush of all the ATF in the system. Takes 18 quarts or so.
Not sure how you got 13.5 qts out. A drain and fill only netted me 3.5 qts. A fluid exchange would get it all out but that's alot more than 13.5 as well. What procedure did you use?
I know i was over but per the MUD thread it stated that the amount you remove is the amount you have to fill up. The guys on the thread were throwing in around 18 quarts because they were removing until they saw fresh fluid. This is what I did but i started to see fresh fluid at 13.5 quarts and thus decided to stop.
I'd not freak over the tranny fluid and simply drain a quart at at time until you've got the correct level.
The operating issue you posted for has nothing to do with it. I suspect you changed the air filter and did not loosen the thick rubber tube connecting it to the intake manifold, instead simply bending it up to get the air filter lid off. Or the previous owner's mechanic did it. This sounds like classic cracking/tear in the bellows section of the tube, and of course it's on the bottom where you cannot see it. Remove it and a close inspection with a bright light will reveal.
DougM
DougM
I did exactly what you state in terms of replacing the Air filter. The air filter replace was done over a month ago with not issues then. Could it now just come up? I am not sure. but i will look into it a soon as i get off. Thanks.
FJ raamis
sounds like you did a running flush of some sorts with AMSOIL synth? :eek:
(you're aware you need to do some voodoo incantations with engine running to check the ATF level with the dipstick, right?)
Yep. Haven't heard of the cold/hot difference, but might be the MAF is running in full rich mode during warmup and the operating issues aren't as obvious. Let us know.
Doug
I have noticed the same overly high ATF level when the truck has been sitting with the engine off for a while. I attribute it to some of fluid in the ATF cooler piping draining back into the pan and raising the level. When I check it with the ATF up to operating temperature (note that this can take a while longer than the coolant temps, as in 20-30 mins depending on driving conditions) and the engine running, the fluid was at the perfect level.
As for the potential cracks showing up in the intake tube, it is possible that you weakened the tube when you changed the air filter. After a month of driving the engine torquing and body sway have finished it off for you. Check it out with a light like Doug said. Also check your ATF level too, just to make sure.
the reading you get on fluid level at cold is unreliable. the best way to measure tranny fluid is when the engine is in operating temperature. run it through all gears then leave it running on park then measure the level. this will eliminate some guess work. hope that it is just an overfill. drain a small amount from the drain plug, if that is the case
DONE
OK All, I was able to do the hose check and the fluid drain. Unfortunately, still the same thing, now however, there is a faint smell of burning rubber. what else can i check.
Take care
FJraamis
