Herculiner!
So I am herculining the floorpan of my 40 I've removed the seats and roll bar and everything else I've cleaned the bolts and put them back in...the plan is to wire brush the whole thing, rub the entire thing down with acetone then hit all of the rust spots with Rust-mort, then primeit with rustolium and roll on the bedliner....what I want to know is there anything else I could do with this to make it better and what do I do about the bed liner around the bolts, and the tranny tunnel...I know a few of you out there have done this and I'd like any info, advice, pictures that you've got
Thanks
Brandon
HERE ARE SOME PICS!
There are actulally two 40's being done at the same time My 1975 and my hausemate's 1974 mine's tan his is blue...
his
Mine
Both
Mine again
The folding chair is a nice touch, I used a bucket.
I just did the same thing your doing a few months back. I found the $6.00 spray gun from Harbor Freight worked much better than rolling it on. I did my rocker panels as well as the interior tub. There are a few good threads on it here and at Pirate if you look for them.
troy
I rolled up paper in each hole, coated the bed, and once it became a littlel tacky I pulled out the paper. Make sure you tap each bolt hole before reinstalling the hardware. Otherwise just go for it. Oh yeah, make sure the surface it real rough and clean. I think you are supposed to use Xylene IIRC. Make sure you wear rubber gloves, and if you're spraying, which seems to be the recommended way to apply, you keep the stuff off your skin and outta your lungs. I rolled mine, and I like how it came out, but next time for ease of application I'm going to buy the spray gun.
Good luck.
Rob
rolled up tape in holes for me.
Also did Tranny cover seperate.
Be sure to remove any tape you used to tape off areas while it is still tacky, comes off easy at that point.
I don't know if I just put it on extra thick with the gun or if it was the cooler weather, but mine took much longer to turn tacky than they said it would. I cleaned the gun immediately after use with the xyleen and it cleaned easy, wait too long and you'll end up buying another gun. Also I went to a auto paint store and bought a little metal bottle that screws on the gun since they don't come with one. First coat I used a gatorade bottle duck taped in place but is sucked. metal bottle was only a couple bucks.
troy
Thanks TJDIV.....Chitown do you have a picture of yours because I was going to roll it on to have better control but then everyone said that rolled on looked bad what do you think???...have you compared it to another one that was sprayed??? what are the disadvantages of rolling/brushing it on?
I don't know about Herculiner but used another similar product called Hippoliner because it's tintable using any color. All I had to do was add a few ounces of the same paint used on the cruiser for a perfect match in red, no less. It's been a year and still looks great.
The sprayers are cheap and worth it if you have a compressor but a good job can be done with rollers and brushes too. I think it takes less product when you roll/brush also.
Hey is there a good/easy way to remove the pad thing on the drivers side floorpan it's stuck on there pretty good
Spraying is always going to look better IMOP, but rolling wasn't too bad. YOu just have to be patient and not try to goop in all on to cover in one coat. 2-3 coats of rolling come out fine as long as you keep stirring the herc keeping the consistency the same for each coat. Also make sure you cover the can in between coats because it has a tendency to dry out quickly making it more like molasses than thick paint. Here are two shots of mine rolled on. The one of th ebed is not faded, just dirty since I never sprayed it out all last summer. Also I did around the lip of the tub and door frames. The crappy line around the edge was from after I had the tub painted and before I touched up the herc/paint line nice and straight.
Hey does yours ever get sticky when it gets hot out?....I've got my first coat on and when it gets hot it gets sticky....is that normal....I was thinking it would be bad to put on the next coat when it was hot.....any thoughts????
