Helper Springs
N: 06° 47.85' | E: 079° 53.38' | Colombo, Sril
Website
mithila.gfoto.com
I've used a similar product for towing a heavy trailer behind a car (sedan), and it worked well to stiffen up the back end. If you just want to lift the back, and use your truck only on the road, and don't mind making the ride harder, it'll probably work fine, but it will reduce your articulation for off-road driving. I'd suggest trying longer shackles as your first step. It's cheap, simple, & effective.
Thanks !. I do fair amount of off-road driving mostly soft ground, mud and water. Not much rock-crawling. So it seems worth a try(not that expensive too).
Thanks again for the input
Another cheap & simple way to stop rubbing is to cut the guards away with a disc grinder. It depends on how fussy you are about looks, but certainly stops the rubbing!
