help with wiring gauges. please!
England
ive got three VDO gauges coming tomorrow, and while im pretty good with a spanner im rubbish with wiring.
what and how is the best way to wire in the gauges? splice and solder to existing instrument lights behind the dash? run wires to the fuse box? run all three wires into a junction box and then splice em? ive really no idea, and dont feel as though you will be patronising as you really wont...
Easy way is to jump of the cigarette lighter backlights. Do a search for cb mic holder from Nakman.
What I did is not the easiest way, but it was the cleanest and most reversible:
I went to a junk yard and bought the section of wiring loom that has the CDL pigtail. They charged me $25 bucks which was a great deal considering it had some of the other pigtails to the center console. I then used the white CDL pigtail cap (the one with the yellow jumper wire that is removed when putting in the CDL switch) and made a CDL extension that is about 8" long. On one end it plugs into the original CDL pigtail (using the white cap) and on the other end it provides the proper connector for my CDL switch (CDL pigtail from donor loom). In between I can jump off the backlight wires to power other backlights. In my case the wiring loom that I bought had two sections of wires that originally were used to branch the backlights off. I reused these sections and they have six wires (three positive and three negative) for additional backlights. If you need more branch off of these wires to save the integrity of your original wiring.
This is probably a :banana::banana:job because you do pull the wires and connectors from the donor loom (using a small electronics screwdriver) and individually trace the wires back to where they need to go but it really was not difficult. I did not have to cut an original wires and nothing had to be soldered. This probably deserves its own write up but if I can answer any more of your questions let me know.
Like I said, the easiest way is from the cigarette lighter back lights. Also, someone can correct me if I am wrong but I don't think there is a true earth. The back lights run through the dimming rheostat so you have to tap into the positive and negative provided in the system. In mine the wires are green with a white stripe and white with a green stripe. I'm not sure which is + and which is - but it won't matter unless you have the replacement LED bulbs (built in diode).
