help with starting
Laurens
I have a 1976 FJ40 with the original 2f engine. I am having trouble getting it started. I have checked the altenator and had the battery check and toatlly charged. Both at a local parts house. Both checked out great. when I go to start it I get a real slow turn over like it is not spinning fast enough to produce the needed ignition. The coil was bought last year. It seems like something is preventing it from kicking over fast enough. With the fully charged battery and it hooked up to my 2001 Suburban and letting it sit for a few minutes it will sometimes fire. Please help. It is warm and beautiful here and my Toyota is wanting to play.
Had the same problem as yours with two completely different solutions:
1. Was missing the ground strap between the bellhousing and the frame. Cheap fix!
2. Distributor was grounding itself out internally from metal filings that were between housing and breaker plate. Replaced distributor...expensive fix.
Engine now cranks over 3 times faster than previously. Used to sound like it was catching on something and slow to turn over before.
