Help with main jets and timing! Please!
I've been in serious fuel consuption in my ´40, its a 79, I uninstalled all the emmisions stuff. Its running like 8miles/gal, Checked the carb, and main jets are 125/165, is that a good relation, I live over the 6000ft.
So,´for finishing tunning up my ´40, what are the proper jets for me? what´s the correct timing for it? 12º??
Thanks in advance!!
You'll get the best answer from JimC, I run 112/180 jets, timing at the bb but my altitude is @650ft tho. but only squeeze out 12mpgs :mad:
Do a search for Desmog or smog and you will find Jim's initial answer. Check the Tech section on the home page as well.
Most 2F's that are desmoged are done wrong. I thought I did mine right and it did not run right. You need a certain amount of vacuum conections hooked up for your carb to work properly. The original connections came from you smog equipment.
After you do a search take a picture and post it to the board of your desmog. Also post up what you removed as part of your desmog.
For example SMog pump, Computer, air rail etc.
Ive been looking everywhere for that, I need pics, 'cause the PO took everything out, and I dont know where to start. But, anyway I need info about the timing and jets.
Start with these:
http://www.ih8mud.com/tech/smog/72706FJ60desmog.jpg
http://www.rzeppa.org/tech/jimcdist.htm
This one is from my desmog on my 1975
https://forum.ih8mud.com/showthread.php?t=52869&highlight=carb
This will give you the general idea.
As for jetting I would make sure everything else is working right first before you change the jets. I have know idea what jets you should run.
Post up a picture of your carb and the vacuum and electrical lines first. If your carb is not hooked up right you will get bad mileage.
I am no expert on carb or distributors but have had similar issues on my 1975 and Jim C and others have helped me, through this board, work them out.
Also you might post up separately and ask for pictures of a 1979 ignition and carburation system so you can figure out what the PO took off. A Manual, Haynes or Factory will help you there as well.
Dave
