Hey, I am new to forum great place to be, lots of great info, thanks. I have had a pretty much bone stock 1982 FJ40 with armstrong steering for 12 years and am taking the next step to be trail worthy. I am adding Saginaw PS, SOA lift, Shkle Rev, 4x labs hi steer reversal, upgrading to 37" tires which leads to gearing issues. The vehicle will be 90% trail 10% around town. The two options that look the most appealing is the Toybox from Marlin and a H41 with an Orion. Cost is always an issue I will be topping the budget out with the lift, tires and PS. The biggest problem I have found with the August 1980 and newer FJ40 is the fuel tank location prevents a secondary Tcase without removing and adding a fuel cell somewhere else. Also the extra 6" and steeper dl angle dosent sound as good either. The confusion with the Orion is it dosent work with the output shaft of my stock H42 because I have the split Tcase?? Is this true?. I was hoping to "Bolt On" a H41 first and add an Orion later, but if they arent compatible then I would have to purchase the H41 and Orion to make it work. Or If I added the H41 I would need a NON Split tcase to go with it. I have read many threads that say the split tcase is the way to go for strength but there really isn't an option besides the toybox that retains the split case and adds crawler gears. Any input would be greatly appreciated.
