Help with engine ID
Ocho77
Alpena, MI
Website
www.op-art.guru
Hello,
This engine is for sale local to me, and I can't figure out which version of the F it is. Can anyone tell by these pictures? I'm contemplating taking the SBC out of my 72 and putting a Toyota back.
He's wanting $400.
F engine most likely about 68 or 69
JP
Intake manifold is the later narrower style. Not sure if those started 71 or not. Yhat was the last year the oil fill was a tube on the side and not in the valve cover. If original intake manifold it is newer then 68 or 69.
The engine has 70-73 carb & manifolds.
Valve cover & oil fill is 68-71.
Logically, the engine is 70-71.
Casting date is on the top of the cyl head & side of block, FWIW.
I didn't realize the wide intake went away went away after 9/69, thought it was a little later. I forget that my 10/69 70 model is after the 3/69 date making it pretty easy to research parts. Now I wish this was closer. At some point would like to rebuild the correct engine for my 70 so I can replace the the early 2F with the correct engine. It's all about being in the right location. I have a 72/73 engine here in AZ. Shipping between MI and AZ is a deal killer.
