After noticing I had what seemed to be some non-functioning warning/indicator lights in the dashboard of my 1995 FZJ80, I searched the forum and FAQ's. I didn't find anything that directly applied to my specific questions. I do have two transmission indicator lights out (Drive and Overdrive), but my main issue is the bottom row of lights in the instrument panel.
I removed the instrument panel thinking I had burnt out bulbs. On the bottom row there are seventeen light sockets. I only have fourteen bulbs, there are three empty holes. Unfortunately, I had already removed a few bulbs planning to do a complete replacement when I noticed this. After shining a light in each hole I found the following:
1) The fifth holes in from both the right and left side don't seem to have any display icons. Maybe these are supposed to be blank?
2) The second light in from the left (next to the Door Ajar light) has a curious icon - a broken arrow pointing down through two rows of 4 balls, each. I couldn't find anything about this icon in my owners manual, so I left that socket empty when I put everything back together. What is that icon, and should it be empty?
The A.T. Oil Temp, Diff Lock (center), and A/T P lights never come on. Should they come on briefly at starting, like most of the other lights, or do they only come on to indicate a condition or problem? My Diff Lock light never comes on, even in 4-LO, and when in 4-Lo, the A/T P light doesn't come on when the transmission is in Park. I'm not aware of any A.T. oil temp problems, but I swapped that bulb with a working bulb that was next to it, and it still didn't light, so I know it's not a bulb problem. My F & RR Diff Lock lights flash, but apparently my lockers aren't engaging. I don't think the PO ever tried to engage them, so they may be stuck. I've tried "exercising" them, as recommended in another thread, but haven't had any luck. (I know that's a separate issue, but I threw it in because the lights do flash)
The previous owner had been behind the dash to do some stereo work, so I suppose it's possible he lost a few lights, or they rattled out. Am I missing lamps, or is 14 the correct number with these three sockets empty in the US market?
