HELP with brake lines
Medford, Oregon
I'm in the process of a rear disc conv. and am installing the downey braided lines, the problem I'm having is #1 the bottoms out on the tee that attached to the rear axle, it's works if I put two brass washers, is it Ok to use two? and the other is the part of the line hits the u-bolt so I can't attach the tee back to the axel unless is turned at an angle, is this OK and has anybody else had this problem. Gotta get it done today it's my DD :D , Thanks
