Help with axels
Hello All,
Please Help!! My front axel does not line up. The engine oil sump and the tranny oil pan are getting in the way - what are my options ??
I am doing a conversion..
Trying to toss a 02 Vortec 4.3L v6 in a 77 FJ40. Probles start with the choice of Tranny I am using.. a 4L60E auto . I am using the stock FJ40 T-case..
adding lift does not help. Reasing the engine mounts also do not helo as I will have to change or modift the hood... Any sugestions ?? Thanks a bunch.
Here are some photos
http://home.comcast.net/~fredieusa/wsb/html/view.cgi-photos.html-.html
i thought that there was a pic of a mod oil pan in TT that was for the 4.3 V6. I think that they had to shave the oil pan to get it to fit. look in Jan/Feb page 27
time to do a SOA conversion.
ridgerunner said:
Toyota Trails, not AA. Mark Whatley (Mark W here) wrote up swapping in a Chevy into a truck that they had to cut and modify the oilpan. Campy- it says "adding lift does not help."
"Does not help" in this situation, is what I ment .....
I had a '94 tbi'd 4.3 in my Cruiser with an SM420 for many years. Theres nothing different the Chevy 4.3 install than a Chevy v8. It looks like your prob is the tranny anyway, not the engine. I am curious though how low your motor is installed. it looks really low. Get some pics of where you have your motor mounts. An advantage of the 4.3 is that you can pull it forward more than the V8, adn that will also help you raise it higher.
Anyway, I have an SM420 tranny, and the drive line yoke's flange needs to be shaved down a little, as well as shaving the tranny's hump. Looks like you need to do something similar. Modify your tranny oil pan by cutting into it a buit and weld in new plate to seal it up. I would also flip your drive line around so that the drive line is thinner near the tranny.
-Dustin
I looked at the pic you have with the oil sump... you need to get your motor offset to the driver side by an inch or so off center. This is true for any Chevy install. That will help with clearance of the driveline and get the tcase lined up. Also, it needs to get moved higher by a couple inches. When you have the motor mounts welded to the frame (so they sit level with the top of the frame) and then have the bushings in there, that will help. If your bushings dont give you enough lift, get another set and stack them, or use the stock I6 mounts- they are like 2 or 3 inches high.
-Dustin
Dustin - Thank for your reply. I am just bout freaking out .. if it wasnt for alcohol ...
I am going to try the suggestions you have listed. Moving the motor over an inch (ti driver side) and up bout a few inches might work ..
Once the engine revs - it will tork and I wonder how much it swings ...
I am dreading to have the in a 2 weel drive config.. :mad: or even cutting out a hole in my hood :mad: :mad:
Calm the f down and have a beer! :D
Check this thread. Hes using the same tranny as you:
http://www.pirate4x4.com/forum/showthread.php?t=336050&page=1&pp=25
You should not have get it so hight that you have to cut your hood. This is just like the other Chevy Vortech V8 swaps, so you should be searching for pics of others that have done them. The motor will torque the tcase down, pulling the drive line away from the oil pans. When you move the motor over, it should also have better clearance from the diff.
I dont have any experience with the tranny you are running, but it looks like youre going to have some clearance issues with the yoke because of that pan, and might not have any choice other than to cut it out a tad. Regardless, you can get everything in and address that later if time is an issue. If its just barely hits the pan, a hammer may be one clearancing option. I would take your makita 4" and round off the flanges on the t-case and yoke regardless. Just take it down to where the bolt heads are, and be sure to have the flanges bolted together when you do gind, so they are smothed out the same...
Good luck, you'll get it figure out. Its a great motor and you'll be stoked on it.
-Dustin
From these pictures I do not see the conflict with the oil pan.
Is the problem with the axle tube, the diff, or the driveshaft?
The oil pan on an 02 4.3 is not the same as the oil on an early model 4.3 or V8. It is Aluminum and can't be hemmered/bent for clearance. There are also a couple of different profiles of these pans, depending on what rig they were in originally.
If you need more clearance from the pan, you will have to cut it and weld it back together. It is not the highest quality casting, so use care.
The short bit in the Trails that was mentioned here was about modying the pan of a '99 4.3 to clear the IFS of an '89 forerunner without a suspension lift. Much tighter than a Cruiser install.
I'd be looking at flipping the springs to push the axle forward if you have diff/axle tube conflict. And do an SOA to get the axle where it should have been in the first place. ;)
Mark...
Would an early pan fit and correct the problem, assuming the problem is the pan and not the tranny?
No. It bolts on a little differently than the older pans. You can be sure I would not had cut and welded the AL one of I could have installed a sheet metal pan and taken a hammer to it. ;)
Mark...
Mark - Thanks for your input.
I am going to toss out the manual stock steering gears as I have the Saginaw setup from AA(this will make room for headers) and move the engine a couple inches to the driver side. That does not work.. I will cut-face-weld the pans..
How will this affect the temprature ? Given it will hold less oil..
I am also reading up on SOA.. Till now I have only read one post where they had baught axels that already had the mounts cut and welded .. Also I am still understanding how it will impact trhe stock springs .. OR will i need new ones that will work...
When I did my SOA last year is wasn't too bad. I baught perches from Rubicon express, then wholesawed to fit cruiser axles. The front p/s was a little more difficult. I inboarded the rear just a smigg. I saw that Faultlinefab has a kit for sale for perches for $60 all four. That's a good deal worth looking into. Depending on $ you can still use the stock springs or step up to ?. Pm me if you want some picts. I'll be wrenching on the cruiser first of next week and would be happy to show you how I did it.
The AA saginaw set up is cool. Just box-in and plate both sides of each frame. You don't want the bolts to pull through :doh:
Campy :cheers:
Don't overpay for perches. Use the mopar "performance" parts from your Dodge dealer. $9.00 per pair. I use 'em on all of my spring over conversions. Open the box and weld them on.
Personally a Saginaw (GM style passenger car) is my last choice for a steering conversion. FJ60, Scout or Astrovan.are all much better choices.
For most people and most rigs, stock springs are the way to go with an SOA conversion.
Reverse the springs and extend the wheelbase. This will move your front axle ahead 3.5-4 inches.
You shouldn't reduce the pan capacity by a whole lot when you modify it. Half a quart or so, depending on exactly how you do it. Keep pickup clearance in mind when you mod the pan.
Mark...
