HELP with antenna!
I need help out of a bind: I just reassembled the factory power antenna on my '97 FZJ80. I forgot to remove the mast nut before I inserted the new mast (I screwed it on temporarily to hold the antenna while I replaced the lower screw). Now, I can't remove the antenna mast in order to remove the mast nut and replace it in the proper order. When my buddy turns on the radio or raises the antenna with the antenna button, the mast comes up, but I can't pull the nylon runner all the way out! Can I force it out, or will this break the power unit? Does the ball at the end of the antenna screw off so I can pass the mast nut up and off? I won't go to bed for several hours, and I'd like to fix this before I go to bed, so I'll be checking this throughout the evening.
Thanks.
The little ball at the top of the mast can be unscrewed if that's what you're asking.
That said, if you've got the mast in the motor housing now, not sure how you are going to get the entire assembly back into the fender and installed :rolleyes:
I tried to unscrew the ball, and it wouldn't give. I tried that on the old antenna too, and it wouldn't give either, only got chewed up. But in the process, I cycled the antenna up and down, and for some reason, I was able to finish pulling out the nylon runner this time. Then I reassembled it in the right order, and it's fine now. Thanks.
Chuco
