Help with annoying Sniper sound
Oregon
Can anyone help me pinpoint this sound? It's definitely not mechanical as it doesn't make any noise when the vehicle is off and the throttle is operated. I believe it has more to do with vacuum, it's more pronounced under a load, when going up the hill etc. The fuel lines are all SS bent by me.
Usually the sound is just a quik chirp when shifting between gears. For the video, I tried really hard to make the sound more pronounced just to hear it better.
I did an inline regulator and hard-capped the outlet vs using the one in the Sniper...but I wonder if it's something in that built in fuel regulator/bypass. Somewhat sounds like a valve chattering when it's riding right at the threshold.
Edit: the chirp between gears does somewhat seem like vacuum though, if it relates to manifold vacuum spiking when the throttle goes closed...
The stainless lines are spiffy, though. :D
@zerotreedelta I've never considered the fuel regulator/bypass on the Sniper body. Yes it sounds like a valve chattering sound for sure. Unfortunately it only does that when driving so I can't just stick my head underneath the hood to diagnose. Thanks for the tip, it gives me another clue to check out.
