I am looking for a little help. I have a 76 fj40 and I am swapping in a 2f from a 60 series (not sure what year) It came with trans and tcase but I decided to use my old one for now so i didn't have to worry about driveshafts etc. So as it sits I have the Engine/trans/tcase all together with all the old mounts but my questions are in regards to the carb and other accessory hookups. There are two hoses coming from the base of the oil filter where do they go? It has an oil cooler but can I just remove it or should I keep it? The carb linkages are not the same and I can't use the old carb as it doesn't fit the intake but can/or should I use the intake from the old one? There is also coolant hoses going to the bottom of the carb can I bypass them? What else will creep up that I haven't found yet? Any help is greatly appreciated.
Grimace
Grimace
