Help Wiring HID Projector Headlights
Athol, MA
I purchased new HID headlights and need help with the wiring. The side marker light sockets, the black and yellow wire, are replaced with the factory socket which allows use of an amber bulb. I will tie the halo lights, black and red wires that enter below the low and high beam sockets, into the side marker lights. I assume the red plug leading from the HID ballast plugs into the black plug next to it? they are a perfect fit.
Now here is the big question, where or what plugs into the three bladed plug that leads to the high and low beam bulbs? I pulled the factor lights and each bulb, low and high beam, have a separate section of wiring harness that plugs into the bulb socket???
I noticed on Slee's site, thanks Christo, that their harness jumper has what looks like a place where a three bladed plug might plug into the factory harness, "A"??? Did I just not follow the factory harness back from the high and low pigtails to find this plug in the factory harness?
I dont think anything plugs into the 3 prong looking connector on the ebay light you have..
once again I cant quite tell, but that looks like a ballast in the pic.. if it is, then the connections are:
connect slee harness low beam to ballast.. connect ballast cable to low beam on headlight.
connect slee harness high beam cable directly to the high beam connector on head light.
The brass 3 prong thing isnt needed...
make sure you have the ploairty correct or they wont light up..
also... there is a lot of voltage going to the ballasts so be aware of that before jacking around with the lights...
OK, I do not have Slee's harness. I shouldn't need it correct?
So, The red connector is male and will plug into the factory high beam pigtail and also the low beam pigtail. The other connector on the aftermarket headlights is a female connector and I can't figure out where this would plug into.
If they are this big of a pain in the %#* to wire I'm about ready to just keep my HIR and soak these things in lighter fluid and enjoy watching them melt.
More pitures
You should just cut off the three prong connector, it's useless.
What I did was to smash 4 bulbs (2 per side) with a hammer (the ones from the OEM lights) and soldered their bases to the new headlight wires. This way I got OEM connectors. No need to buy any harness.
The side marker bulb holders can be replaced with OEM so no need to fuss with that. The halos should be spliced to the side marker lights. The three pairs of wires on the bottom are for the LEDs. Just give them a good pull and get rid of them, they don't look good.
So you end up with two wires for the high beam and two for the low beam. The wires for the high beam are obvious but the low beam wires are not. You are using HIDs so you have a ballast. You should connect two wires to it (to give electricity) and also only two wires should go from it to the bulb. These should be really well shielded as there are over 22,000 volts sometimes. You don't want to cut such a wire. They are usually wrapped in steel mesh in order to cut on intereference caused by such high voltages.
I am currently away and I am writing on a dinosaur era laptop. Really harsh conditions. I will be at home within 2 days so if you don't get the right answer just send me a PM.
