HELP!!! What's the name of?
Olean, NY
My 1996 fj80 needs a part desperately that evidently I have to get from a junkyard. It would not roll over or start. I assumed starter. Put new one on and a few hours later, would not roll or start. Was told by the garage that the problem was a bumble cluster of wires has corroded or something and caused a short. I need to try to find the part. Wife hates the rental, so I am wondering the name of the (pigtail) part that has 6 wires or so going into it and it plugs into the tranny evidently Land Cruisers don't have relays. Does this make any sense. t is 6 wires going into a plug thing that goes into the tranny. Evidently when they were trying to start it, it began smoking and they figured it was surely the problem. They said something about it was the plug that goes into the \neutral safety switch. I am no mechanic and need to know what part to look for. Please help!!!!!!! My phone is 716 548-2010 so texts are great as well.
have you tried the fuse link at the battery terminal? i've had issues before where it won't start even after i put a starter and alternator. played with the fusible link and it would start. cleaned it up and no issues for a year now.
i would clean the battery terminals and check that link.
I think you ought to isolate the part, remove it and post a pic or otherwise and go about finding a replacement. The rig isn't running anyways and if something's smoked or fried you're not likely going anywhere. A fusible link at the battery has 3 connections.... he's stating 6 wires into a plug at the N/S switch. Something's up with the harness. Why it fried is the real question. Whatever's fried check any connections on both ends and be sure the components are good. It could just have been a heat related insulation fry that caused a short in a particular section of the harness. Good luck.
