Help Wanted
Factory head unit? If you went aftermarket, I'd pull it out and see if something detached. That said if a plug in play harness was used it shouldn't be the case. It may depend on the brand but it seems like I remember seeing a fuse in the back of some aftermarket head units. Its been a really long time since I've dealt with them so my memory is a little fuzzy.
Sounds like you have a different problem than what I mentioned but it wouldn't take long to check these simple connections and fuse. I'd atleast give it a look.
I had this issue last month. The factory amp was on its way out the door. I put a new amp under the passenger's seat (I drive a RHD) and problem solved. . . along with much better sound now that all speakers are changed as well.
