Well, I've read about a hundred or so posts I've found after searching variations of "Knock", "Ping", "Tick", and "Slap" and still haven't found anything that seems to describe my engine noise.
My 95 FZJ80 has 171K well maintained miles. The PO had the maintenance records and I confirmed it when I took the head off to replace the head gasket as a PM item so I could tow with peace of mind. There wasn't even much discoloration inside the valve cover compared to pics of others I've seen posted here, and the cross hatching was still visible inside the cylinder bore.
A machinist used by the local Toyota dealer milled .006 off the head to clean up the fire ring grooves, replaced the valve seals, and ensured the valve seats were still sealing. I also had the fuel injectors reconditioned. My miss has disappeared and it runs smooth as a baby's butt.
I've put about 500 miles on it since the work and now notice, what I initially thought was valves ticking, under certain conditions. It seems to be getting more noticeable. It sounds like metal tapping metal. I can hear it constantly when driving at high rpm's (3500-4000) so I'm afraid to do any towing. I can also hear it when I rev it when parked. If I rev the engine to 2500-3000 RPM's, let off and then hit the gas again the tapping noise starts as the RPM's change from dropping to rising.
Using my $5.00 Harbor Freight mechanics stethescope I've been able to determine that the sound is heard mostly in the block. I can hardly hear anything in the head.
When listening from the exhaust side it seems like it is coming more from the top of the block. It's hard to tell, but I hear it more from the front of the engine, but I can also hear it pretty well by the #4 cylinder area. I might be able to hear it all across the top of the block, but I haven't had much chance to put the rod from the stethescope all over without interference from other parts deadening the sound.
I did have some issues with the timing chain when I put the head back on, but I don't hear the noise on the tensioner cover at all.
Is is possible that by shaving .006 off the head that the valves are intermittently hitting the tops of the pistons?
Is is possible the chain is hitting something, could valve/piston conflict only occurr under certain rpm conditions?
I'm at a loss and wanting to get this cleared up before pulling my trailer on vacation. Any help is appreciated.
Thanks
Steve
Thanks
Steve
