Help w/Saginaw Gearbox
Montgomery Co. TEXAS
Website
missionsonwheels.org
I've bout finished installin the Rock Logic hydro-assist ram. When I pulled the top cover off the Saginaw gearbox I found the threads that run up through the cover where screwed up, thus screwing up the threaded cover and bolt. I cleaned up the threads, replaced the cover with a new one (after tapping it for the hydro-assist), bolted everything back together and now I have PS fluid leaking out of the top cover from under the center bolt on the aforementioned threaded rod.
I've never had a gearbox apart and ain't real sure I got the cover put back on right. What do I need to do to fix this?
Thanks,
