Help w/missing alternator adj bolt 1FZFE (1 Viewer)
Fort Collins, CO
After a long road trip over the mountains in my 95 FJ80 1FZFE the alternator adjustment bolt appears to have backed out of its bracket and is missing -- and possibly any washers, etc.
Can anyone tell me what size the bolt is and if it had any washers etc? Is this something I can procure from my local fastener supplier or must I go to Toyota?
Any help is appreciated!
Thanks!
Onur
51422-60140
Moderator
GOLD Star
Tabasco, NY
About 90cm long, M8 X 1.0
Fort Collins, CO
Thank you--I should've been more clear. The bolt that's missing is the shorter one that passes through the square block that the longer bolt is threaded through. I can see the back of the bracket, but I suspect there was a nut and washer too? Or maybe I passes through the square piece and threads into something on the alternator bracket?
Again--thank you for your help!
Bob
Onur
51422-60140
Moderator
GOLD Star
Tabasco, NY
Yes, clarity does make a difference.
90080-10200
M10 X 1.0
About 40mm in length.
It threads into the bottom of the alternator.
