Help verifying readings on knuckle centering
San Diego, CA
So I am currently reshimming my knuckles after borrowing the SST from another mud member and was hoping someone could chime in if my readings look to be within reason
Left Knuckle
A 167.22mm (with a bearing preload of 9.5lbs)
B 164.97mm
C=A-B = 2.25mm (total shim thickness)
D=4.3mm (distance between scribed lines)
E=D-3mm = 1.3mm (lower shim thickness)
F= C-E - .95mm (upper shime thickness)
My results for the right side are identical so I will spare writing the math out.
Thank you for any help yall may be
