help towing
Alabama
Website
www.auburn.edu
so I hooked my fj40 to the tow bar the behind my tundra. transfer case in N and trans in N. ok let go start to drive. hear click click click. stop check hubs. unlocked ok trans and transfercase in N ok. start to drive click click click. What the hell is that clicking noise. as I drove alittle faster it got faster. I gave up. did not hit the trail today. yall have any ideas?
If you have a bad pinion bearing it will make a noise when the ring is driving the pinion as oppose to the pinion driving the ring. I found this out when the electric fuel pump went out that a PO had installed in a FJ25. I noticed a little noise when I would let off the gas but when I was being towed with the engine off I could really hear it. If not that I would pull the rear drive line and make sure the front one turns free. If you don't hear the noise then it's check your transfer. If you still hear it you have a problem with your axles or brakes. Lock right lockers and other of the same type will make a clicking noise but that is only when cornering.
John
