What "light retainer relay"? Not seeing that I'm the FWD.Can you hear the tail light relay come on? If so, check for 12 volts at the TAIL fuse.
If you dont hear the tail light relay I would suspect the combination switch or the light retainer relay if your LC has one.
My LX EWD shows it. Im not sure if your LC has it. There are some threads on here about it.What "light retainer relay"? Not seeing that I'm the FWD.
I found a speaker had a come that fell out and hanging by wires. Then I thought the wires touching caused it. I glued the cone back in thinking it was fixed.My LX EWD shows it. Im not sure if your LC has it. There are some threads on here about it.
What ever happened with your radio issue?
Found the tail light issue. (Friend's 94 LC)Can you hear the tail light relay come on? If so, check for 12 volts at the TAIL fuse.
