Help! Stuck throttle
North Pole, AK
Hello all,
Well, my wife went to work this morning and had the throttle stick wide open. Fortunately, she was smart and put the Cruiser into Neutral before rear ending the car in front of her. The Cruiser did, however rev to 5k RPM for a second. :rolleyes:
Anyways, I picked the Cruiser up and towed it to the shop. I can't replicate the problem. Both the throttle and Cruise control cables are not frayed or rusty. They freely move. Help!! I have no idea what would cause this. It's running great now, unless I can figure out hat happened, I won't let her and my 4 year old in the vehicle.
Thanks
TK
How about a very dirty throttle body? IAC valve?, not sure if these have a tps sensor or not but I would believe that would set an ses light. Keep us informed, and glad the clan is ok.:steer:
On my old 82 SRS pickup and 84 Subaru my throttle cable sometimes use to freeze in REALLY cold weather. Figured it was from water getting in/on the cable somehow and then freezing. Sometimes pumping the gas pedal would "break" the frozen spot, sometimes not. Nothing quite like the scare you get when you're cruizing along (on the highway in my case) and go to let up on the throttle and have nothing happen :eek:
It seems wierd that water can freeze under a "hot" hood but I've had it happen. More common to have it happen after driving and shutting down on to have the throttle cable stuck later or the next morning but I have had it happen where the engine has been up to temp. Figure water got splashed up and due to the extreme cold flash froze while the throttle was in a constant state (highway).
My only suggestion would be to look for any spot where water can get to, freeze, and cause the throttle to stick - cable, cable attachment points, etc. Put some grease or something in those areas so even if water does get on that area and freeze it won't freeze the cable, just the grease :) - Hope that makes some sense
If she is sure it wasn't just her foot slipping onto the gas pedal instead of the brake, and the rig has the original throttle cable, I would replace it. How is the outside covering of the cable, peeling off in places? Was she using the cruise control?
My throttle cable was getting notchy and was not returning to idle normally when I took my foot off the pedal, scary a few times at stop light. I replaced the cable and clean/lubed the linkage etc. and the symptoms went away. Also got a smoother pedal feel. Also would perform a throttle body service and lube the linkages.
You don't have a hand throttle installed do you? I found that mind would sometimes hold the throttle open when I didn't expect it due to faulty adjustment.
Other than that, considering where you are, tempature related, sounds like a good possiblity.
Well,
I looks like the cruise control was the culprit. It somehow iced up while she was cruising at 55 and held the throttle until it thawed. I wouldn't have thought that something so close to the motor could freeze. Anways, I bought all new cables and sprayed them with WD-40 to displace moisture. Thanks for all the input.
TK
Well,
Yeah, neither did I until I experienced it first hand. Quite unnerving when you're cruising along at 65+ mph and come up to a toll booth, release the throttle, and nothing happens :eek:.
Glad you got it figured out :cheers:
