HELP RTH Dizzy O-ring
Richmond, VA
I just replaced the dizzy o-ring.
Marked everthing accordingly and noted position of the rotor before removing.
Put it all back together and started it up and it is running bad.
Does the ECU needed to re-learn again?
I am a bonehead!:doh:
I knocked off a vacuum line in the process and did not see it.:doh:
Put it back on and all is good now she purrs like a kitten:)
Thanks
even if you made marks for everything you need to set the timing, do you have a timing light?
No timing light.
It runs great.
Does not feel any different than before I changed the o-ring, except it does not leak oil anymore.
you should still check the timing. buy or borrow a timing light.
How do you check the timing?
It has been a really long time since I have done that.
I cannot even remeber the last time I did that.
Maybe highschool?
You do have the FSM dont you?
ignore the references to the lexus hand held tester:
EM1G0–02
ENGINE MECHANICAL – IGNITION TIMING
EM–9
Author: Date: 501
1996 LEXUS LX450 (RM482U)
IGNITION TIMING
INSPECTION
1. WARM UP ENGINE
Allow the engine to warm up to normal operating temperature.
2. CONNECT LEXUS HAND–HELD TESTER OR OBD II
SCAN TOOL
(a) Remove the fuse cover on the instrument panel.
(b) Connect the LEXUS hand–held tester or OBD II scan tool
to the DLC3.
(c) Please refer to the LEXUS hand–held tester or OBD II
scan tool operator’s manual for further details.
3. CONNECT TIMING LIGHT TO ENGINE
4. CHECK IDLE SPEED
(a) Race the engine speed at 2,500 rpm for approx. 90 seconds.
(b) Check the idle speed.
Idle speed: 650 ± 50 rpm
5. INSPECT AND ADJUST IGNITION TIMING
(a) Using SST, connect terminals TE1 and E1 of the DLC1.
SST 09843–18020
(b) Using a timing light, check the ignition timing.
Ignition timing: 3° BTDC @ idle
(Transmission in neutral position and A/C OFF)
(c) Loosen the hold–down bolt, and adjust by turning the distributor.
(d) Tighten the hold–down bolt, and recheck the ignition timing.
Torque: 18 N·m (180 kgf·cm, 13 ft·lbf)
(e) Remove the SST from the DLC1.
SST 09843–18020
6. FURTHER CHECK IGNITION TIMING
Ignition timing: 2 – 13° BTDC @ idle
HINT:
The timing mark moves in a range between 2° and 13°.
7. DISCONNECT TIMING LIGHT FROM ENGINE
8. DISCONNECT LEXUS HAND–HELD TESTER OR OBD
II SCAN TOOL
WOW!
No FSM.
Ok I do not remeber it being that difficult.
I will get it checked.
Thanks
it is not that difficult, piece of cake,
