Help....Ring gear preload?
Raleigh, NC
I am installing air lockers and I can't seem to find the proper ring preload. Does any know how tight to torque the adjuster nut on the side opposite the ring gear?
Snug the adjusters up against the carrier bearing races...make sure you have your backlash set properly, .006"-.009", and you will be good to go!
Shouldn't have to mess with the pinion unless doing a gear change. Just torque the ring gear onto the ARB carrier, set the new bearing adjusters to give backlash as per Poser above and be done with that part.
IMO the worst part of an ARB install is that dumb copper line. The first time I had to make a new one because I tried too hard to do it neatly and kinked the copper. Not hard, but it pissed me off for a little while.
