Help! Res line on king rubbing badly
Villa park ca
Help!
I am getting seem serious rubbing on the line to the reservoirs fromt he kings.
The rubbing does not appear to be not the upper arm, but from the tire! I the driver side is rubbed through to the stainless lines- passenger side looks ok?
I’m running 285-65-18’s on a 18x9 wheel with 40 offset? I would think that’s plenty to clear the line- ive seen other need to run spacers to clear their stock wheels?
What other fixes are there?
Turn the reservoir so that the fitting isn't sticking straight out may have to get a clamp and anchor the hose to the frame.
If thst doesn't work, maybe you can buy a set of mounting plates and relocate the reservoir
Thanks,
It worked well, i clocked (rotated) the resi about 20 degrees (downward) that gave me about 3” more of clearance and is not rubbing the coil
That worked really well, i appreciate this as i wasn’t seeing the solution until it was pointed out to me...
This forum rocks.......
