Help request - having a '96 with rebuilt engine inspected
San Diego
I'm having a '96 inspected this weekend, and it's had a lot of work done on it. I think this is a good thing, but I'd really appreciate getting feedback.
The engine truck is about 200k miles, with the engine and differential redone in the last 5k miles.
It has new:
- ball joints
- struts
- water pump
- plugs
- tires
- gasket seals
- crank shaft
The owner says it runs smooth and has always passed smog. Carfax is clean.
Con: there's a clicking noise when the steering wheel is turned.
I'm thinking that this is a nicely maintained truck, and that these fixes are a good thing, but I'd really like to hear what others (the experts) think.
Do any of these items either independently or in conjunction with one another signal anything to look out for? Any other thoughts?
Thanks in advance.
If the engine was a full rebuild you should have all new hoses, belts etc, sparkplug wires blah blah blah. Do you have pictures you can share?
The clicking makes me think birfs...if that engine was really rebuilt or if it was just an upper rebuilt head...then I would still rather tackle the birfs than the engine rebuild and feel pretty enthusiastic about it.
If they have the receipt for the rebuild etc that would be encouraging.
Everyone is going to ask for pics on here.
I would want to know why the engine was rebuilt, see receipts what parts were replaced and what machining was done. At 200K a full rebuild is not normal but just a head gasket would be more realistic. Replacing the crank indicates a severe failure from lack of maintenance, oil starvation, over heating etc. At minimum I would like to have a transferrable warrantee on the engine.
Thanks. It’s a full engine rebuild according to him, wires, hoses, etc. I’ll confirm it in the inspection. Seller has a lot of paperwork too, it sounds legit so far.
I’d love to share pics but don’t have anything useful at the moment. It’s out of town but I’m having it inspected in the next day or so, I’ll try to get some pics at that time. Will toss up some lower res images here if that fails.
so the truck dosnt have ball joints, you have trunnion bearings in the front knuckles. you also don't have struts, it has shocks on all 4 corners.
new shocks and a front axle rebuild at that mileage would be fairly normal, but clicking while turning could be coming form the birfs and if they were bad the time to replace them would have been when the axle was getting rebuilt.
id want to find out more about the engine rebuild and see what else was done. what is the asking price on the truck and does it have the factory lockers in the front and rear axles
Interesting, so then we have some red flags.
- calling out the wrong repairs
- birfs not addresses in axle rebuild
- he specifically said it’s never failed smog, but Carfax points out a few failures over the decades, including recently.
And the latest and weirdest:
He said the engine was rebuilt because it had a lot of miles on it so they rebuilt it (what???)
The ask is $6500. No lockers. It’s a CA truck with the pro being good maintenance/PM but this is getting odd.
I asked if he means it was just a top end rebuild then, as PM, we’ll see what he says.
I may need to eat the Carfax and move on from this one before getting into trouble, but it’d be really good to find out what’s up here. Any other questions come to mind to give clues on what’s going on? For the sake of curiosity as much as posting a warning to the For Sale forum.
So it will be interesting to at least find out the results of the inspection as well... the inspection you ordered was occurring this weekend, right? It is rare to need a rebuild at 200k, but if they had a head gasket failure and overheated or perhaps something else random, it wouldn't necessarily be deal breaker to me. The main red flag in my mind is why is he getting rid of it so soon after a rebuild -- a rebuild surely cost the better part of that $6500 asking price.
If he comes up with receipts, a head rebuild should be in the $2500-$4000 range. An entire ENGINE rebuild would be in the $4500-$6000 range.
An axle rebuild would be in the $1200 range.
All numbers are if a SHOP rebuilds it. If an individual does it, it would be about half of those numbers.
The dude stopped replying after I asked whether it was a top end or full rebuild, in response to the bit about rebuilding the engine 'just because it was high mileage'.
Looks like this will most likely stay a mystery. Something was definitely up, I'm just not sure what.
Thanks for the discussion here, really appreciate it.
If anybody thinks it'd be good to post the original listing somewhere, I will do it. Otherwise I'll assume it's best to let it fade away.
Just post it here for fun :)
Hey maybe it's all good, and I'm being overly cautious. If so best of luck to any of you, it'd be great to see something good come of it.
Looks to be a brand-new Tiyota......
Rebuilt engine
New tires
New axles
New Pistons
New differential
New transmission
New water pump
New radiator
New plugs
New wires
I assumed that the transmission, water pump, radiator, plugs, and wires are new, because it did not specifically say so.
If the items listed were actually new and engine was rebuilt 4000 miles ago, they should be asking $18K for this truck.
Engrish as a third-language.......
Run.
