Help - Replacing Headlight Assemblies, need better Lowbeams!
Hit an elk while traveling this weekend, smashed out both headlight assemblies. So I need to replace them, is there anything better than the standard US spec assemblies? (Euro, aftermarket?) Especially on lowbeam?
I HAD HIR bulbs in all four head lamps.
The elk was standing on the yellow line when I saw it, I was not able to slow down much before hitting it.
My wife and I have never been happy with the light output of the lowbeams on our 80, especially in canyons.
Is there any better options for low beams? Bulbs, Head lamp assemblies, driving lights? I really want to be able to see further without blinding on-coming traffic.
Thanks,
Jule
:bang:
From Toyota Land Cruiser FJ80, FZJ80 and Lexus LX450 Parts For Sale
Headlight L or R
91-97
New Toyota light assembly.
$189
Used headlight assembly
$125
I guess you could go with the sealed beams from 91-92, but you'd need new mounting hardware. I think.:meh:
At lease you could aim the lows and highs where you wanted 'em.
I grabbed a couple of Sylvania Silver Stars for my low beams. The light is a little whiter, but some say they don't last very long.
Theres a couple things you can do.
1. You can use the original assembly and just get a better halo light bulbs such as the philips or other good brands mentioned.
2. Retaining the original light assembly you can purchase an aftermarket HID conversion kit. Theres a 35w and 55w output system available. But i dont know wheter is legal for you to do the conversion to HID in your country. If you can then its good but make sure you reallign the headlight to fire down instead of up. If you dont do this you will blind oncoming traffic with it.
Im assuming that you will be driving alot in the fog? Do not get the 6000k color spectrum get something like 4800k or 5000k plus. Hope this will help you in making your decision.
Sealed beams never came on 91-92 in the US. You're thinking of the 88-90 FJ62.
To the OP: I'm surprised the HIR's didn't do it for you. I have just the low beams and it's a HUGE difference. Though, I also have the Slee upgrade harness...
another suggestion:
Mount a set of additional driving lights...
you did have the Slee Headlight Harness installed, right? My understanding is the Headlight Harness noticeably increases headlight output when used in conjunction with upgraded bulbs. There is info about the Harness upgrade in the FAQ, IIRC.
Nah, just the foreign FJ80's I guess. Some people like the look, but I can't really see them having a better lighting pattern.
Most people I've talked to about them say that same thing. It's definitely got the cool factor.
Bug Zapper, Maybe?
Most of my driving experience is with whitetails, then again:
4xoddic-albums-lx-stag-sound-picture1316-lx-stag-sound-%3D-attempt-fit-5-25-component-system-w-option-revert-oem-appearance.jpg
I drove graveyard shift for 5 years for the Corpse (e added for emphasis of land stewardship) of Engineers here in KS. Mostly in Big 3, but '75 was in an International (!), just to give an idea of 70s' DOT (state of the fart) lighting tech. No aux lighting, unless you count the flasher bar on top.
From my observations, deer don't stand in the middle of the road most of the time, waiting for headlights to stare at. They're off to the sides, browsing. IF they spook when you come rolling in, they may decide to cross to the other side of the road for the same reason the chicken did (?). In your case, the elk was transfixed by your headlights & froze, which is what they usually do anytime there's an alarming event (very strong instinct).
Major problem is that you may see the first, but likely not any others if they decide to follow the leader.
FOR THESE REASONS, aux. lighting will do a lot more good in avoiding a collision = see deer/elk on side of road, slow down, await critter to decide on who has right of way.
Headlights in canyons (or any curved road) only light up in the straight line, so unless elk/deer is in that path directly ahead & road is straight until that position, it's still coming out of nowhere when your headlights do line up.
Speaking of FJ62 lights, the Hella Euros I had threw a much broader heighth on R edge of beam = i_I (ignore dot). They also would light up the ditch & shoulder MUCH farther than DOT-legal. At 30 MPH, you can still read a street name sign in a neighborhood up until it's 2-3 feet in front of bumper. I don't believe there is an easy FJ80 equivalent to obtain that pattern, other than aux. driving lights.
I'm not familiar with aux. light patterns to name a specific lamp to suit this purpose. Nor where to mount it on OEM FJ80 bumper (elk = excuse to get ARB, maybe?). The light will have to either have a wide spread (LH may stimulate oncoming drivers to FLASH you); OR be positioned to light up roadsides, rather than roadway where your headlights shine anyway.
From a Physics perspective, the HIR bulbs & upgrading the harness make more light than DOT-legal BLING bulbs (w/shorter lifespan).
WHAT REALLY WORKS? = Shortening your reaction time. I trained my driving in a MG Midget at an early age & once pulled over into the width of a sidestreet when center lane driver made a R turn as I passed him. (Had to live through it to believe it. At my age now, its even tough to imagine the response skill involved.) I would've flopped an FJ80.
Have your reaction time checked (Corpse had a trigger test w/light board; most Ophthalmologists have the apparatus). Practice, practice, practice. As you age, your time will lengthen. Any behavior which slows your time = greater time to initiate maneuvers to avoid collision. The elk/deer is doing the same thing, only is not sure what's going on (you won't know either until the ungulate decides).
Speaking of roadkills, I had a student who brought in unborn twin fawns from a doe. Although they had no hair on the hides, the spots were quite visible. Did you get to keep the elk meat?
:hillbilly: :hillbilly: :hillbilly: :hillbilly: :hillbilly: :hillbilly:
COWS are another matter. Considering they don't have the sense to turn their rears into the wind in a blizzard = suffocate when nostrils plug with drifts & freeze over.
:doh:
IF Bison are in the road, pull over immediately. Hopefully, they'll mistake you for the range cube truck & follow in behind.
:grinpimp:
Caution: all observations in these 2 posts are purely experiential and should not be assumed to be SOP on the part of any roadside ungulate. Behavior during rutting season may NOT follow any rationale known to man nor beast.
