HELP please headlight wiring?
Lexington, KY
Hello,
I need to "hot wire" (with a switch) my lo beam headlights temporarily (long story).
Can someone please tell me what color the wires are in the steering column connector? 1994 80 series
thanks,
Steve
bump ttt
If I am reading the EWD correctly, the wire from the "light retainer relay", located under the dash, to the light switch on the steering column is black with blue stripe. The wire from the switch to ground is white with black stripe. This is on/off for the low beam headlights and taillights. High beams use a different wire.
Is it true that all the current for the high beam headlights goes through the headlight switch in the steering column? I would expect there to be an intermediate relay like the low beams have. Weird.
Based on obscure physics, Toyota likes to switch circuits in the ground side of the circuit.
The C14 switch does indeed switch the hi-beam current. Finding a hot (+12v) lead from the Hi-beam switch may not be easy - lots of tape wrapped wire bundles. "Splice point" E2 may be the easiest, left front of cruiser near the head light assembly. Tap this point and bring back into the cab.
Connector "EA2" is near the fuse panel.
Ref: EWD189U, Pg 64.
Clear as mud, huh?
k0dar
thanks for the reply's, I'll see what I can do.
