Help on fuel lines!!
1976 FJ40 that has never run well. The fuel system has had plenty of modifications so I decided to make some changes. First, the aux tank was leaking so I took it out. Now I’ve got to get everything back to what it should be and everywhere I look I find other problems. First pic is of the two lines coming through the floor. One goes to the fuel selector which I’d like to bypass now that the aux is gone. Second goes to the return line which is actually capped off below the fuel filter. The second pic is of the main fuel line. It’s connected to the selector. The line from the collector (pic 3) used to go to the aux tank, then a line came from the aux tank back to the fuel selector. So selector had 3 lines. One from main tank, one from aux tank and one to the main line to the fuel pump. That made sense, but where does the line from the collector now go??? 4th pic is selector.
I have a Weber DGAV 32/36 according to the stamp. But it sure looks like an E. When I ordered the rebuild kit I also ordered the manual choke conversion so that shouldn’t matter going forward. I missed my old manual choke I had on my 73 FJ. The carb is a mess which is where this journey started. Probably just needs to be cleaned up, or maybe the choke is sticking. Don’t know, but once I started tracing back from carb to fuel source nothing looked right. I’d like it to be right.
Bonus pic of the mess I need to clean up in the engine compartment. May get a new wiring job. That’s been rigged plenty in the last 40+ years too.
Anyone got the answer to this? Its be de-smogged and every diagram I can find is with all of the smog stuff on it.
DGEV is with an electric choke. DGAV is a water heated choke. DGV is manual choke. The single vapor collector line goes down to a check valve in the tub behind the door, then under the tub to the charcoal canister in the engine bay. The three vapor lines off of the tank go to the collector, and that looks legit. It looks like your air cleaner has fitment issues.
Where did you get your manual choke conversion? I would like a good one for my DGEV as well.
JTOutfitters has the manual conversion for $18. Figured what the heck since I was already ordering the rebuild kit. I forgot to order the new filter assembly. Another one of the things that just isn’t quite right. Mine says DGAV but has electric leads running to it. I saw somewhere there was a conversion there too. Who knows. I almost just ordered a DVG to just skip the rebuild, but what fun is that?
Where does it go after the Canister? I am not sure I have one. If not I have no idea where to find one. Is that a vapor line coming off the collector to the canister or is it actually a fuel supply? That would make sense that it was running vapor to the aux tank.
I’m thinking there is a union or something I’m missing that brings together the line from under the tank and maybe a line from the canister. Especially since the return is blocked off. Does the Weber have a return or is that just coming back from the fuel pump? Mine has a bolt screwed into the return which makes me think there was a threaded connection that is missing.
My old 34/34 progressive Weber had one fuel inlet and no return, in my opinion if you want good performance get a OEM Aisan carburetor, I've had a Weber, Trollhole and now a Aisan on my 78 and it really out performs the rest. FYI the Aisan has an inlet and return but you can run it successfully with just an inlet.
I am currently running a return on my DGV on my '85 Nissan 720 because the return line is just OEM Nissan/ Datsun plumbing right before the carb. You might find the necessary plumbing in a salvage yard, but I think that my Nissan part might require changing from Toyota's 8mm to 6mm after the fuel pump, then switching to a smaller inlet on the Weber (easy), then back to 8mm on the Toyota return line. The DGAV and DGEV share the same castings short of the choke housing, the DGV is totally different. I bought the same basic choke conversion, that you ordered, for the DGEV, at O'Reilly's for like $10, then I got one from Pierce Manifolds that was only available on Amazon for $25 that included a choke cable clamp on the choke housing which worked much better.
The Weber has the option of left or right fuel inlet, the side not used has the, "bolt" that you described.
A charcoal canister (for the DGAV/DGEV Weber carb) is pretty generic. It has a ported vacuum connection which goes to the vacuum distributor advance line off of the Weber, a purge hose to a manifold vacuum source, and a fuel vapor source from the check valve after the vapor collector, after the fuel tank. My DGV even has a float bowl vapor purge akin to the OEM Nissan/Datsun carb
I have yet to crank my 2F, yet, maybe tomorrow. However, I am seriously considering the extra Weber I have because I can probably obtain the correct jets for the rig to run at really high altitude (like 8,000' or 9,000') at a stoichiometric air/fuel ratio.
Here is a pic looking up at the fuel filter. That is the return line that runs next to the main fuel line. That is where the bolt is in he end of the line. I also found a hard line coming from under the tank to the engine bay that is just cut off. It comes out the same hole as the soft line that was running back to the aux tank. I assumed that line was coming off the collector but now I need to verify. Is the check valve just 9” down the line from the collector??
My original symptom that started this project was dogging out when I gave it gas. I could keep it from happening if I barely press the gas pedal but it made driving it difficult in traffic. It would backfire if you held it down so I just assumed the secondary may be clogged making it over lean. It sat for a long time and had the wrong filter. Just figured there is no way this carb is clean, and I have an ultrasonic.
I don’t mind replacing everything that shouldn’t be there. Was hoping to find a basic description or diagram for what you “need.” Like main fuel line to fuel pump to inlet on carb. Now run from check valve to canister or just leave it capped if you don’t mind fuel smell. (I’d rather not have the smell). I had honestly never thought of a new fuel cap, but that’s cheap to and I get rid of my locking cap. Vented or non vented. I also like to remove stuff that isn’t used or necessary and just have what I need. Makes troubleshooting way easier.
My rig isn’t a show rig and won’t be. I drive it around town in 35 MPH zones. I take my daughter to school in it and drive around the ranch. No need for a snorkel. No rock crawling. I’m a pilot, so I’m not worried about the look. I just want my stuff to run well. If it weren’t for some minor rust I’d probably never paint it and just leave it rough. I like the look it has now.
The SOR drawing calls it (your third image next to the seat belt spool) a, "separator." On its upper line, that runs over the fuel filler neck and down to the plastic, white check valve (look behind the door jam), it will tie into a hard line and go into the engine bay to the charcoal canister. A vented gas cap might be okay, but a hot fuel tank can produce a ton of gas vapor. A later Cruiser tank actually has three separate compartments (and three vent hoses) within its upper portion, so basically, air can't get out thru the filler neck to a vented gas cap from the driver's side compartment or middle compartment until the fuel is really low, or it bubbles thru the liquid portion like a bong.
The tank has a braided hose that helps you keep gas from spraying back out the filler neck when you are filling it up.
In the middle of the cab, two lines connect to the tank. The upper is the fuel return, the lower is the fuel draw that goes to the fuel filter then fuel pump. I believe that others on this forum described the fuel return line as a typical delete on a Weber.
What kind of backfire? Intake or exhaust?
I can’t remember for sure, but I thought exhaust. Sounded starved for air but I took off air filter and there was no change. That’s why I went to carb clean. Since I ordered on line I figured I’d start going backwards to the tank and see what I found. Maybe I’ll learn one day not to go looking for issues.
I have the braided hose in tact. I need to check that check valve. It looks like an Inline filter. Need to make sure it isn’t. Is there an easy check for the checkvalve?The hole for the return has another hose that went to the aux tank. I suspect that might have been some kind of over flow to the old aux tank since fuel would drain from the main tank to aux. it’s a soft rubber hose. Right now I just looped it to the old supply line from the aux tank to the fuel selector. That fuel selector could really use a plate on it, or at least writing on the floor in sharpie. If that is a vent line I have screwed up.
So people are just going to the charcoal canister with the line off the collector, with a check valve, and stopping there? Seems like that should go somewhere.
Exhaust backfire isn't likely related to your tank. It is incomplete combustion, too rich or poor spark or retarded timing.
Your check valve looks like mine.
The OEM FJ40 charcoal canister goes to the Vacuum Switching Valve. Let's see an image of the passenger side of the firewall, kinda low, that is where the OEM canister is located.
Most of a charcoal vapor canister's function is not dependent on engine vacuum or temperature, so you can probably wing any old canister because your carb is not designed with the OEM FJ40 specific emissions. Can we see an image of the very spot where the vacuum advance hose is plumbed into the Weber? I know the valve cover is kinda in the way.
Here it is. The canister is gone. If it’s just taking the vapor and going nowhere I guess any canister would work. Just taking smell out of the vapor.
I’m thinking cap the old line that came out to the old aux tank, then remove supply from the old fuel selector and connect it to the supply that goes to the fuel filter then fuel pump. Take the line off the collector and go to a new canister
So at the bottom of the image is my charcoal canister on my '75. I have a hard line that runs under the hood lip that goes to the Vacuum Switching Valve (top of image). One of the two other lines goes along the edge of the running board to the check valve (which can be verified for function, according to Haynes). One of the other lines (from the bottom of the canister) goes to a rib on the bottom of the body and terminates into the unknown. The one on the top back of the canister goes to the check valve.
On my DGEV, there is a vacuum line, which is capped with a screw, just to the left of the vacuum advance line. That isn't, 'ported,' and it goes to an orifice right under the throttle plate. There is a similar set-up on the stock carb after the vapors leave the Vacuum Switching Valve. You might use that for what is drawn from the charcoal canister
Tuning this Weber is going to be important in keeping the 2F running right, or that is my guess at this point. I suggest that you pull a spark plug or two and lets see if you have carbon build-up. Timing should be performed with the vac advance line disconnected. Have you tuned the Weber before?
That is exactly what I needed. I ordered plugs, wires, cap and rotor. I’ve never tuned a Weber before but I think I can handle it. Figured starting with fresh plugs was a better idea for troubleshooting. Was going to make one change at a time so I could see if it made any difference.
I found that line to nowhere. I tried to figure it out and gave up. The vacuum is going to be the next thing to figure out.
Bonus question. Why is the secondary barrel black? Took jets out and they were all clean. Emulsion tubes clean too. Would make sense that there is an issue on secondary given the backfire when I push it a little.
There is actually a throttle stop on the secondary, because it does not close real tight with the barrel.
If you have glowing carbon on the edge of your intake valve, or the plugs are glowing hot, then you can have intake backfire. I'd expect the secondary to singe before the primary, because too much air is being pulled thru the primary, but once a flame starts in the secondary, if you kinda close the throttle vacuum, can't pull the flame it into the manifold.
What size jets, primary and secondary? Idle, main, and air corrector? Is there a tiny hole drilled into the throttle plate(s)? It looks like you have tiny bolts. Gotta a photo of a typical spark plug? Are you running EGR? Is this a US or Cali '76? Stock distributor?
Spark too advanced can cause intake backfire. It gets too hot in the combustion chamber when it is too advanced. I might be mistaken, but I think that folks on the forum are dialing their distributor to 14 deg Before Top Dead Center, capping the vac line and just letting the distributor do mechanical advance (warning, an improperly seated distributor will disable an oil pump and trash a motor, I did it before doing a tune-up). Too little air in your air/fuel ratio can cause intake backfire too, because it causes glowing carbon build-up which causes it to ignite before your plugs fire.
Still no carbon canister anywhere?
I’ll get the jet sizes since the carb is now apart. I did another test tonight that I didn’t expect to fail. Turned the key to start with the fuel line off. Nothing. I let it spin long enough that it should have had some fuel. That’s a part I really dont want to swap unless I know it is bad.
I’ll pull some plugs and get jets tomorrow. I keep backing up trying to find something that works well so I can say, “we are good to here.” Haven’t found that point yet. So far I know I have the correct ignition key.
I keep thinking it may be time to stop and start over. Feeling like the more I do the further away I am.
It looked like your carb was apart, if your jets are in there, leave them in, but record the sizes (if you can easily read them) for further use.
What does the end of the hard line, after the check valve, look like? Is it capped off?
The check valve is described as two-way; it lets vapor out and air in. Try leaving the gas cap off the filler neck when you pull the fuel line, or air horn, from the carb (so it can drain back). Try leaving it off when you crank to refill the bowl after reassembly--this way, the fuel pump does not have to work against a low-pressure situation.
The end of the hard line is just cut off in engine compartment. I had the cap off yesterday when I cranked it with the fuel line off the carb. No fuel. Now no starter either. Verified it’s bad.
My eyes are no bueno for reading the little jet numbers. Since I’ve got no flow at the carb I’m thinking there is a problem I need to fix and I’m best off not changing anything on the carb. It starts with starting fluid. That’s why I went to the carb. Would have been much smarter to take off the fuel line and check that first. Lesson learned. Still concerned about the black side of the carb but maybe fixing fuel flow fixes this.
Now I’ve got to go back to tank. Yesterday I put in 2 gallons. Today I have fuel under the tank. Thats a problem I need to fix but I can do that later. Verifying that I have fuel coming out of tank to the hard line is priority #1. Then clear line to pump. If I verify fuel supply to pump isn’t that where you say to replace pump? I see a lot of posts about going electric but would rather have original if possible.
