Help on door inards removeal!
Anchorage, AK
I am removing the inside door panels on my 78 doors. I want to get it all clean out and pull the lock and latch so I don't scratch them while sanding. I have the panels all free, and the inside latch, but I can't get the darn crank for the window off. Any help???
thanks
Ryan
hope this helps or you can wrap a rag in between handle and door trim and pull clip of this way
WARNING! Using the "rag trick" will immediately result in launching the godfrappin clip so damn far across the shop, you won't find it for eleventy-seven years! Don't say I didn't warn you!
Ryan;
Just did mine last nite. Good write up in FSM 98154.
Get yourself a small needle nose pliers and carefully push in the panel while slipping the needle nose over the clip; grasp same and pull up and out. The needle nose should be around 4 inches and have teeth on the end of the blades. A decent hardware store or maybe Radio Shack may have these; common electronics tool.
Dude-
Thats perhaps the sweetest diagram on the entire site. Woody, maybe we can get that thing in the tech section...
sweet pic :) honestly it made me laugh out loud, AND it got the job done!
Rezarf <><
