Help on 3rd dome Light
Alabama
Website
www.facebook.com
After installing my 3rd light in the rear hatch light stays on on both "on" position and "door" position. Doesn't matter if doors are open or closed in either position. I pull my power directly off of the lightbulb itself in the 2nd row as I made 2 wire ends that clamp to the bulbs ends for power. The 2nd row works just fine it goes off with the doors yet the cargo light stays on. Wiring is not my strong suit by any means, any ideas how I fix this hopefully without pulling the headliner? Thanks for your help
Not sure but I think you should have pulled power from the wire going to the second row light and not the bulb itself. If I understand correctly the bulbs are triggered by completing circuit to ground and that's what you probably did accidentally.
There should be a wire harness at the left rear piller area, that is for the third dome light. Not sure what year yours is but. it was there or just under the headliner on my 94.
Mine is a 95 no harness there
