Help - OME Steering Stabilizer
Bogota, Colombia
Would appreciate any comments/suggestions:
Took my FJZ80 to the dealer for steering box gaskets replacement, after a couple of days they called and said the truck was ready, I picked it up and was told by the agent they had to weld one of the bolts of the steering stabilizer (OME) (bolt was the one that goes to the frame), it was broken (weird), I went home and after a couple of days driving (not wheeling) the truck I heard a noise, went to look underneath and saw the steering stabilizer hanging (the bolt they welded broke). Went to a friend's repair shop, he had one new spare bolt, we just replaced it. Same day, after just a few miles driving, heard another noise, went underneath and saw the other bolt broken (the one that goes to the steering link) and the stabilizer hanging...
What can be causing these to break?
Thanks in advance.
The OME stabilizer shock is in good working order right? It's not like seized or can dented? Did you try and compress it by hand completely before mounting it back up? Only thing i can think of is that something is stopping the shaft from compressing and it snaps the bolt under full lock..
Yes, forgot to mention, I can compress it /decompress it by hand, looks in good condition. :confused:
Weird. Re-weld the stud again. Put the front axle up on jackstands and turn the truck on.. cycle the steering left and right and see whats going on with it. Only real way your going to find out whats going on at this point. Actually you dont even need to put it up on jackstands.. just have a partner turn the steering wheel while you check. Something has to be binding somewhere.
