I need help ASAP as '94 80 is my DD. My CEL was on so I tried the paper clip route to check the flashes (per troublecodes.net). When I accidentally touched one of the leads (end of paper clip was not inserted into the incorrect OBD 1 plug in), a small (and I do mean small) spark was generated and I immediately pulled the paper clip. I then get the paper clip touched to the correct leads in the diagnostic box, and the CEL goes out with no flashing CEL ever occuring. I go to start the truck and it won't start...just turns over as normal. The only other thing I can think of is the truck does have a "PRIMAL Security PVS-300" security system with keyless entry. I had earlier unpluged the security system to do a little cleaning behind it, but plugged it back in prior to starting. I am doubting that is it but, being an electrical idiot, I sure could be wrong. By the way, I checked the two ECU dash fuses and both were fine. Any thoughts will be appreciated and I really need to get this fixed today!
