HELP! Nuts In My Pan?
I believe, correct me if I am wrong, but you can remove the front timing cover without removing the head. The secret is that the oil pump is removed so the front cover has some "wiggle" room. CDan commented on this when I kinked my head gasket trying this procedure without removing the oil pump. This may be an option, or you could just hope for the best.
I'd be a tiny bit curious as to the actuality of this. I know I've done it plenty of times with 22R(E)s. But clearly a different motor. And at least dropping the pan helps A LOT. This is a mother of an oil pan. More like an OPEC jacuzzi!
Oh...and don't by his truck used--DOH!
The 'official' way to remove the front timing chain cover is to remove the head and both oil pans. The TC cover can be removed by dropping both pans and leaving the head on. This is a big job because there are some dangling bits below the pans that have to be removed and the engine has to be raised a few inches. The TC cover can be removed by removing the head and leaving both oil pans installed. This is also a big job.
-B-
If anything, I'll drop the pans first. If i find it there then i don't have to enter the TC cover.
