kcustom73
Stretched it...
I finally getting around at assembling my NP203 range box to mate it to my splitcase and need some help. I didn't get instruction with the adapter (no matter how hard I tried) and I'm hoping that someone who's done this before can help me out.
So in this first pic I've got all the parts layed out. I've got the shaft installed on the main gear (with a little bearing grease on the shaft before sliding on the gear), the little pin and the indexed washer.
I'm thinking the next part to go on is the assembly to the left of the shaft held in place with small snap ring above the main shaft. All the washers (flat & lock) and the hex head bolts are to mate the splitcase to the adapter.
I figure the large sealed bearing is pressed in as shown in the below pic with the large snap ring controlling the dept on the bearing.
What I can't figure out is what to do with the spacer ring (to the left of the small snap ring), the 2 black studs, the 2 nuts and the solo hex head bolt (the one standing in the pic). For the guys that have done this build, please help
