HELP!! no FD
Wisconsin
so last trip up on the trails it seemed that i lost my four wheel drive... im not sure how but i did some test to check what it might be... hubs, xfer case so on... i came to the conclusion that when i pull on the FD tab in my cruiser that it wasnt engaging... i dont know what i should be looking for i looked briefly at my hoses connecting to the xfer case and they all seem to be there but im gonna just put new ones in today cause new is always better but if thats not it what else would i look for... im in major help... i have a trip tomorrow to go cruise with some local 4x4 people a mostly yota trucks and i dont wanna have to back out cause i can get my 4x4 to engage...
thanks for reading hope its enough information ill be at work from 8am to 4pm but will be checking this thread constantly cause i work at in a mechanics shop and will be using the lifts after work to try and figure it out
-crazylandcruiser
Check the steel tubes that connect the vacuum diverter to the actuator on the nose of the transfer case....I have seen these get corroded and not allow engine vacuum to get to the actuator.
Has this worked fine in the past?
Have you had the truck in deep water in the past for any significant time?
I have also seen the actuator on the nose cone of the transfer case corrode/rust up inside preventing the little lever mechanism from moving freely.
You can verify that the valve on the firewall is functioning properly by removing the hoses from the actuator, starting the truck up, engaging the front drive and then try placing your thumb over the end of one of the hoses to feel for the suction/vacuum. If your engine is not in the best running condition, the vacuum leak created by the hose not being attached to the actuator could cause it to run poorly, or not at all, in the event that the vacuum selector valve on the firewall is functioning properly.
In the even that you have vacuum to the actuator and you still are not getting the front actuator to move, you will need to find out why. This is easier if you remove it from the nose cone, but might be able to be done from under the truck. I prefer to work on things on a bench in front of me. There are four bolts that hold the actuator onto the nose cone. Do not worry about not having gaskets for putting this back on later. I have used milk carton in the past to cut out my own gaskets and it has worked great.
If you have the Chassis and Body manual for the earlier trucks you will see how this whole mechanism goes together. It is not complicated at all, but does have areas that can get corroded and create problems. The flat cover held on by six bolts, iirc, covers the linkage, and the six J-hook bolts and nuts retain the cover containing the bellows.
It is really strait forward in the event that you need to dive into this. This was one of the first problems I had with my Red truck back in 1988. Really no big deal.
Good luck!
-Steve
thank you very much for taking the time to read and tel me all you know i did all the test you did and i figured it out so ill be out on the trails tomorrow mostly cause of your help thank you very much again oo and by the way my lines were getting suction but they need a little cleaning and then the 3/8 rubber hose had a nice size crack in it also probably limiting me from going in to 4x4 so im good now thank you very much i cant thank you enough
