Help needed - removing old steering box
Houston, TX
I have unbloted all of the nuts and been trying to remove my old steering gearbox.
As I try to remove (along red arrow), the steering column (red with circle at end) gets in the way. Actually, the plates (marked by blue) comes together just before the box can clear the screws at the bottom (marked yellow). For some unknown reason, there are threaded bolts there - if they were simple bolts that went the other way i guess I could slide it off.
Any help appreciated - without taking the steering column out.
You need to grind the rivits off the mounting bracket and drive them in with a punch. After you remove the rivits you can remove the whole unit. You will need to replace the rag joint (the lower blue thing). Bolt (temp) on the new bracket line everything up and mark the holes on the bracket. Remove the bracket and drill holes,mount bracket, mount new gearbox with pitman arm from old gearbox mounted and new rag joint on it. Bill
A hot wrench works wonders on it :D Followed by a small sledge...;p
Guys, I don't think he wants to remove the bracket that holds the gearbox, just the gearbox.
You don't have to take the column all the way out, just loosen it so you can get some more movement. Same thing you have to do if you want to replace that coupler between the shaft and the gearbox.
Is there any reason you don't want to mess with the steering column? Like the previous guy said, you just have to take out the 4 bolts on the floorboard then loosen the U-bracket on the dash. takes about 3 minutes then the steering column slides up a bit an allows everything to come out. Would be a lot easier than removing the bolts on the bracket.
And if that is the case, I would suggest just cutting the old mount right off with a cutting wheel. Made my life a lot easier!
Bill, ran my first trail with PS today, what a treat! Thanks again man.
Rezarf <><
If you are doing the mini truck ps swap then don't bother with unbolting the gearbox from the bracket. Fastest way to remove the bracket is a torch/plasma, second and just about as fast is an air chisel (but loud as hell), next is a grinder.
I just drill the heads of the rivets gone and then knock the remainder on through. After doing it other ways I've found drilling with a 1/2" sharp bit easiest and quickest.
