Well, an update for anyone who might be reading. I had to take the alternator off, because the battery was dead. The battery was fine, the alternator was shot. Called CDan, talked about the brushes on the alt. Checked the brushes, they were fine. New Alternator is on its way. I don't know if this might have caused the problems with the locks. Will check once new alternator and battery are in, hopefully tomorrow.
Just for further clarification: With the door locks, neither one of the door switches, DS or PS, worked to lock the locks. The locks seemed to be constantly switching to the "locked" position, even when already unlocked. I could occasionally lock the doors by hand, but within about 2-5 minutes they would be unlocked again. That is without anybody touching the switches, the key out of the ignition.
Again, all fuses that are readily accessible check out fine, all relays that are readily accessible are fine. I have not taken the DS door apart to get to the relay that is specifically for the door locks.
