Hey folks,
I've been doing research on mud for a couple of days now but I might need some direct help from the community.
While driving home from a 2000 mile roadtrip last september, there more or less suddenly (or maybe I recognized it only then when I was leaving the autobahn and everything came more quiet with reduced speeds) after driving for 400miles without a stop was a noise starting to come from the engine bay. It sounded like a compressor whine and was linked to rpm in terms of noise level. A mixture of whine and high rpm rattle.
While still driving at lower speed, I started to figure out what it could be. as soon as I turned the A/C off, the whine was gone. Hitting it back on, the sound came on again too.
Prior to that for some weeks, I recognized the A/C was not cooling as ice-cold as it used to.
I decided to adress that whine later and keep on driving with the A/C turned of for some months.
One thing that I was noticing when the engine was running: the magnet clutch seemed to not fully disengage as it ever so slowly moved at a very low rpm (1-2rpm) - not constantly but more or less jerking.
Recently I got into changing the magnet clutch (ordered from partsouq) which, except for space issues fiddeling with the retainer clips, was a nice job due to all the information provided on ih8mud. Huge thanks for that!!! You're an absolutely amazing source of knowledge!
I changed the tensioner pulley bearing as it was already rattling, spun the other pulleys but they seem fine. I set the gap of the magnet clutch to 0.6 by use of the shims (might reduce to 0.4 by changing the 0.3 to a 0.1mm shim)
What I noticed while disassembling the old clutch: there was no gap I could get a feeler gauge in. None at all - maybe 0.05 max... Taking of the clutch, the 1.49mm washer came out but no shims at all. I reused the washer and reassembled.
After starting the engine, the clutch did not engage at all. But due to the established gap, was not turning at that low rpm anymore.
I took the rig to a A/C-shop to get a refill. They showed me there was no refridgerant in the system at all. I know I am having a leak but we filled up anyway (1050g as I am having rear A/C as well in the 2005 LX) to detect the leak.
The clutch enganges fine now but sometimes a little stuckering which might be due to a little too wide gap. I think it did not engange first because of the pressure switch registering low pressure and protecting the system.
The A/C is running strong again, cooling really really well front and fond.
Regrettably, the whine is back whenever the A/C is on.
The noise seems to come from the area of the compressor / fan pulley. The power steering and alternator seem to be quiet. New V-belt is on.
I uploaded a soundfile: <iframe src="" width="640" height="564" frameborder="0" allow="autoplay; fullscreen" allowfullscreen></iframe>
The sound in the cabin is more like a whine, while it is a whine with vibration in the engine bay. Once the clutch is engaged, at idle the whine comes on slowly and more quiet than when stepping on the gas but builds up sometimes on its own. Immediately once the clutch disengages, the whine is gone. The sound has some sort of diesel tacking.
Any suggestions on how to further narrow the search for the faulty part or suggestion of the problem?
Btw one leak of refridgerant can be seen on the A/C-line next to the compressor (don't know yet what that part is called).
Every input is welcome!
Thanks, Ruben
Thanks, Ruben
