Hey everyone — looking for some help diagnosing an issue on my 2019 GX460, about 117k miles.
I’m supposed to leave for a two-week road trip soon, so the timing is not ideal.
The GX was just at Lexus for an oil change and general checkup. I asked them to test the battery while it was there. They told me the battery needed a charge but otherwise tested fine.
A few days later I was working on hardwiring a dash cam using power near the rain sensor. I was working on it for an hour or two because I was getting some odd behavior and could not get the camera to power on correctly. When I checked the wires with a voltmeter, I was only seeing about 8–9 volts. I then checked directly at the battery and saw the same thing.
I started the GX and the voltage continued to drop. I went inside to grab my wallet because I figured I needed to go buy a battery, and by the time I came back out, the truck had died.
I pulled the old battery, jumped in my wife’s car, and bought a new X2Power Group 27F AGM battery. Installed it, and the GX fired right up, but then died. I started it again and it seemed to run, but now the A/C will not come on. The A/C button lights green for about three seconds, then shuts off. I tried the HVAC reset procedure, but no change.
I also disconnected/reconnected the battery terminals thinking maybe it needed a hard reset after the battery swap. Still no fix.
Current voltage readings:
Engine
Before I throw an alternator at it, what would you guys check next?
My current plan is:
Any help is appreciated. Trying to get this sorted quickly before the road trip.
- Around 11.8–11.9V while idling
- Drops to around 11.3V with accessories running
- The truck has died again after restart, so it seems like it is running off battery only and not charging.
Engine
- P0335 — Crankshaft Position Sensor “A” Circuit
- B1422 — Compressor Lock
- B1449 — Air Outlet Damper Control Servo Motor Circuit, Rear
- B15DB — Telematics Transceiver Disconnected
- U0233 — Lost Communication With Side Obstacle Detection Control Module, Right
- C1AEC — Front Sensor Communication Circuit
- C1AED — Rear Sensor Communication Circuit
- Several additional telematics-related codes
My current plan is:
- Fully charge the new battery.
- Check voltage at the battery with the engine running.
- Check voltage at the alternator B+ stud with the engine running.
- If the alternator shows 14V but the battery does not, chase the fusible link/charge wire.
- If the alternator also shows 11–12V, assume alternator or alternator control circuit.
