Greetings, I'm a recent buyer of a 1997 1Hzj 80. Love the vehicle and want to start rebuilding her soon for a bullet proof Nicaragua vehicle. I bought it with 428k km on it knowing that I would likely do a rebuild in about a year. I've only had it since November and have only put on a about 2000km and in that time, she's one from needing a half a quart of oil every couple of fills to needing a quart a fill. It seems absolutely crazy to me as it isn't blowing a ton of smoke on acceleration. There is some, but I've had diesels a long time and this is certainly less than the turbo diesels I've had. There is also a lot of oil kicking out the air intake. Not in the air filter, but at the junction of the intake rubber and the metal. So much that it is now dripping down on the exhaust manifold cover. One final note is that it is extremely dusty as of the last month and a half and I just blew off the air filter which was completely coated in dirt and likely strangling the engine. Hoping that helps a bit. I read somewhere that there may be something like a PCV valve or a metal filter under the valve cover that if clogged, can cause excessive oil to blow back and be consumed. Is that true? Any ideas on where to start here? I'm completely bafffed by this as it makes no sense! Thanks in advance for help.
