help!! need advise HG??
i was driving home today, stopped for gas suddently i see alot of white smoke form the tail pipe, i was only 3 miles from home so i decided to drive tons of white smoke coming out the back. temperature rose to about 280 but i made it home. I know i should of probably had it towed but i was so close i got it home and shut it off. this is my daily driver and i need to reapir it as soon as possible. Can any one please tell me what parts i need and what i should repair while im in there? Could i have cause additional damage driving it home? i am pretty sure its the head gasket seeing white smoke and high temps and studder in idle. Please help need list of parts and while im inthere items thank you.
Cruiserdan has a "kit" he has put together for it.
There are a ton of write ups availible on it, as well as a DVD that IdahoDoug has put together (I think that's who did it). Searching the forums and the FAQ will turn up dozens upon dozens of results.
We've had about 5 HG threads here in the last month alone that would answer all your questions.
Call Cdan and get him to hook you up. You might want to post up your location and offer free beer and pizza for local cruiserheads to come help you. Good luck.
First dothe searches and then start looking towards diagnosing! Check your oil/how much water is left in radiator etc etc. There are so many helpful threads here on Mud. That DVD sounds like money well spent as well!
ok i got the DVD from Dough I tried to reach Dan yesterday but he seems very busy i will try again today can any one tell me where i can get a FSM for a 95 LC for a reasonable price? thanks
Damn! Another HG - Join the crowd. Has anyone else had to replace two...besides me?
Dan must have his shaman doll out because he's totally frustrated dealing with the recall BS or he found extra inventory he's got to move. :D
It's in the FAQ.
You can get it off the Toyota Tech site. $20 for all the PDF's you can download.
In a word: Yes.
I can't tell you how many engines I've seen completely toasted and permanently ruined because people didn't shut down the engine at the first sign of trouble. Once the problem is noticed, there is already a loss of coolant, and it only takes a few moments to raise the temps inside the engine high enough to cause major damage.
The only reason you should not pull over immediately and shut down the engine, is if you cannot safely do so where you are. If you can get off the road onto the shoulder, or immediately completely off the road, do so. RIGHT NOW. Not 5 minutes later, by then the chances of greater damage is many times higher than when first discovered.
If you really got the engine hot enough that it registererd 280 degrees on the temp gauge, then things got a whole lot hotter inside than is healthy.
I would take a really close look at all the bottom-end components, and definitely check everything for cracking and warpage.
If someone brought me this engine, I'd recommend tearing down the bottom end and replacing the rings and bearings, as a minimum. When internal parts get too hot, there are a whole lot of things that can go wrong inside. Rings can lose their temper and you'll then have zero compression in that cylinder; pistons can get soft and leave piston material on the sides of the cylinder bore. heads (especially alloy heads) can get so hot they actually start to "shrink", and become useless and non-rebuildable.
In a word, given a choice of running an engine (for a limitied time) without oil or without water, I'd choose running it without oil, every time. The damage is much less, and much more contained. Excessive heat damage can quickly become catastrophic.
What year 80 and mileage?
Man this month is starting to scare those of us with 175k miles on the OEM headgasket. Seems that my turn is just around the corner and I find myself driving across states for work sometimes...
Illcruiser - check your PM box.
No reliable way to know if your HG was replaced without a receipt. It's not a hard job - just time consuming. Tools are not much more than most shade tree mechanics already have. Cdan has an excellent kit for all the little bits you'll replace.
As for your own vehicles, be sure to keep the coolant system clean and filled with fresh fluid every other year, clean the rad external fins with a spray on degreaser once in a while, and pay attention to gauges. I'd give strong consideration to that coolant reservoir alarm someone painstakingly documented a "how to" on Mud for 80s. If both mine did not have new HGs, I'd definitely do this because it will instantly tell the driver coolant is exiting the vehicle - even if it's a wife or daughter driving. Hard to ignore a buzzer/flashing light. Otherwise as noted you may not even realize something's wrong until the engine's running rough and that means stressed components.
DougM
DougM
where is that thread exactly?
